noteven
Sep 17, 2018Explorer III
If it is a tandem it’s not bad if it is spring and equalizer suspension as long as you don’t bottom the equalizer completely. Some weight starts to transfer off the trailer front axle to the low end axle and to the tow vehicle hitch if you are nose high. Use as low a drawbar as you can get your hands on. Tow without weight distribution you don’t need it with your truck and a 6000lbs trailer.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 27, 2026
