Likes_to_tow
Oct 21, 2015Nomad
For all intermittent or weird brake problems the first thing I would do (after all the easy obvious stuff is checked) is remove the brake wire from inside the axle where they route it to the other side. Factories drill a 3/8 hole in the axle on one side and run the wires through and come out the other side through a 3/8 hole.
Where the wire enters or exits these small holes shorts will occur. Also where the wire lays inside the axle tube it will chafe.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 18, 2026
