nevadanick
Aug 11, 2013Explorer
If it has brakes they should be used. You can check the model brake controller specs you have to see how many axles it will support. If its not up to the number of axles then you will need a second controller. Dont let the naysayers discourage you about towing doubles, just check the laws in the states you travel.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
