I've owned three 5th wheel trailers and non of them would slide a tire when I got them home. I owned and put over a dozen equipment/enclosed trailers in commercial service and they also wouldn't slide a tire when I got them home.
On everyone I would R&R why they weren't working. As Marty says trailers in service are required to lock and hold.
The first thing I did with any trailer is get rid of all crimp type connectors especially clam shell type. I solder all connections. In some cases I go with a larger wire. After all that is done I do a amp check at each brake. Checking for 12v may not get the best performance as just a couple of strands from a cut/chaffed wire can get you 12v.
After all the R&R is done all my trailers brakes will slide the tires at any speed if I crank the gain up enough.
