bbells
Mar 07, 2017Explorer
Unfortunately, I already checked the brakes and bearings, and moved everything from the front of the trailer to the back (no fluids in trailer either). The trailer is level, I made sure of that when I re-setup the WHD. Plus, I have a hard time believing the WHD plays no part since it did not do this before I changed the setup. Unless, of course I had some kind of damage that I didn't notice and an axle is bent or something. But then I should see unusual tire wear. I will do a test by putting the WHD where it was and post the results. That should eliminate the wHD as the cause of the problem.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
