newman_fulltime
Mar 07, 2017Explorer II
My first thought is are all the tires the same size it really sounds like the rears are smaller putting more weight on the fronts or the rears are breaking down causing more weight on the fronts or the trailer is not level when hooked up
Correct to set up wdh jack the rear of the vehicle up a little with the trailer hooked then apply the torsion bars then lower if you are simply hooking the chains ad grunting them up its not correct also you need the ball head tilted correctly to throw the weight to the front tires of the vehicle
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
