bbells
Mar 07, 2017Explorer
BurbMan, I am trying the easiest things first, of course. Then doing one thing at a time to see if it got fixed. First I checked the trailer hitch vs the tv hitch when uncoupled and level. The trailer's hitch was a little off from the truck hitch. I have moved the ball to match it. This means I also had to adjust the chain link tension for the torsion bars. I will try this as soon as the winds reduce. It is 50+mph right now. If this doesn't do it I will next rotate the tires. If that doesn't give me an answer I will check the axle equalizer links underneath. I am sure one of these things will work. I am retired. Gives me something to do. Thanks!
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
