aftermath
Mar 09, 2017Explorer III
What kind of tires do you have? Are all 4 the same? If you are starting at 50 lbs inflation there might be a good chance that they are under inflated. An under inflated tire will flex more and build up heat faster. If all of your tires are the same and if all of them are aired up to the max on the sidewall then this shouldn't be an issue.
Swapping the fronts and the rears sounds like a good problem solving option. Let us know when you do this.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
