fj12ryder
Feb 08, 2018Explorer III
Turtle n Peeps wrote:Absolutely, and you should get someone to help you get the right size, and someone to help you get somewhere safe. You probably shouldn't be out on your own.fj12ryder wrote:
"I find it hard to believe that “blowouts” on 2-3 year old tires of any type is anything but a road hazard or overloaded/under inflated tire in most cases. Remember, one small screw can turn “properly inflated” to “under inflated” as you drive. Several year old tires are another matter."
You may find it hard to believe, but it's true. I blew out two tires that were barely 2 years and less than 8,000 miles. Pressures were good and not overloaded. In fact there was about 2500 lbs. on "E" rated 235/85-16 ST tires. Just poorly constructed tires.
So I should replace my tires every year? :h
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
