groundhogy's avatar
groundhogy
Trailer has sat awhile, should I be scared about my tires?
My trailer tires have sat close to a year.
I have heard of people having blow outs and in my imagination, Im thinking if you let your tires sit on one spot, will they get like a hard spot? And it will wear harden.... kaboom...
someone tell me Im crazy
  • groundhogy wrote:
    Ok, Im not near the trailer at the moment, but what Im hearing is that it depends on how old the rubber is?
    How many years old rubber would start to make you guys nervous?
    I think 6-10 years is when many replace their tires because of the age. You should check for cracking or other damage.
    Find the DOT code to determine the age of your tires. Don't go by the age of the RV. A new RV could have tires that are a couple years old.
  • I always cover my tires when parked. I've gone as long as 8 months in between uses (dang winter) and never had a problem. I check them thoroughly each spring and keep them properly inflated.
  • Ok, Im not near the trailer at the moment, but what Im hearing is that it depends on how old the rubber is?
  • Many rigs sit 6 mos of the year. If they are less then 5-6 years old then just air them up...inspect and enjoy. Beyond that I would likely get new tires.
  • How old are the tires? Were they protected from direct sunlight? I’m a three year replacer. Many are two. Much cheaper and easier to replace at home than on the road.
  • Maybe yes, maybe no. But if you have doubts at all, get new tires and have peace of mind. Simple. Done!
Looking for advice before your next adventure? Look no further.25,164 PostsLatest Activity: Sep 18, 2025
