jblancharddds's avatar
Feb 18, 2021
trailer jack on a tow dolly
Is it possible/advisable to put a trailer jack on a tow dolly? I'm thinking when I park my class C for a quick overnight, it would be so easy to raise the dolly with the trailer jack, move the rv slightly forward, level the rv and then the next morning back up the rv, hook back up and go. This would be so much faster and easier than backing off the vehicle and having to strap down again the next morning.
  • Tal/IL wrote:
    You should not disconnect the dolly from the towing vehicle with a towed vehicle loaded on the dolly. It can be dangerous.
    Key word, "can". Just depends what the tongue weight is and how much you can lift.
    To be fair, I only recall pulling the dolly off with toad on it, once. It was a Uhaul dolly with a Chevy pickup on it. POS Uhaul truck needed repairs en-route and it was quicker and easier to just drop the dolly w/ toad to take the truck over for the night for repairs.
    I recall grabbing a piece of 4x4 lumber that I had for a wheel chock, pulling the dolly hitch up and my wife stuck the 4x4 under it to keep it propped up. Toad was parked in gear to not roll.
    But a jack would work superbly.
  • Set the brake on the toad. I don't see a problem. Just don't drive off in the morning with it set.
  • You should not disconnect the dolly from the towing vehicle with a towed vehicle loaded on the dolly. It can be dangerous. Here is a pretty complete instruction video on tow dollies. Disconnecting a loaded dolly is addressed at about 8:15 in the video.
    https://youtu.be/i2VLlxx2MHo
  • It would seem very feasible and easy, if that's what you wanted to do. Just go to the local trailer place or farm store and get a jack with the right heights and a universal rectangular U bolt side mount plate.
    But do you need one? Tow dollies don't really have tongue weight. I've disconnected them with a vehicle on before. Although it could get stuck and need some assistance. Jack would be easier if you had to do it regularly.
  • bukhrn's avatar
    bukhrn
    Explorer III
    fj12ryder wrote:
    I'm not really sure I understand the question. If you're not unloading the toad, why do you need to unhook from the motorhome? Can't you just level it with the tow dolly hooked up?
    I do !!!!, only time I unhook is if I have a back-in site.
  • I'm not really sure I understand the question. If you're not unloading the toad, why do you need to unhook from the motorhome? Can't you just level it with the tow dolly hooked up?
Looking for advice before your next adventure? Look no further.25,149 PostsLatest Activity: Jul 17, 2025
