SoCalDesertRid1
Aug 05, 2016Explorer II
mowermech wrote:This right here is the correct answer.
This ol' retired mechanic doesn't believe the trailer has anything to do with the braking problems. There is just no way that I know of that the trailer brakes can be feeding back through the brake controller and causing the tow vehicle brakes to actuate. Even if the wiring is incorrect, if just can't happen, AFAIK!
Now, you say you recently redid the rear brakes on the tow vehicle, and to that point you had no problem. Now, after the brake job, the first time you towed the trailer the brakes overheated and locked up.
OK, sorry to be the bearer of bad news, but that tells me that something went wrong during the recent brake job. I believe you need to take those brakes apart and carefully inspect everything very carefully! Having it inspected by a professional might be a good idea.
Oh, yes, and keep your foot OFF that brake pedal unless you are stopping and/or need to keep the vehicle from rolling!
I'm going to guess that a 2003 Cherokee probably has rear drum brakes and will add that possibly the rear drum shoes could be installed backwards or the hardware was installed wrong. Take it to a shop and have it looked at.
And as others have said, STOP RIDING THE BRAKES!!!!
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
