Adam_H
Aug 10, 2016Explorer
enblethen wrote:
Another item, could be the flexible line that feeds the rear brakes. Fluid could get hot and cause an internal collapse.
BINGO.... Not saying this is your problem but I have replaced MANY flex lines in 10+ year old vehicles for doing exactly what you describe after the brakes get hot. Now that your controller is adjusted correctly and your brakes are not working as hard, it might not happen. That is until another situation causes the brakes to heat up. When the inside of the flex lines goes bad, it acts as a check valve. FWIW
Adam
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
