acritzer's avatar
acritzer
Explorer II
Apr 26, 2015
Trailer nose down?
I asked this as part of my larger thread on setting up my hitch, but at that point it didn't get much feedback.
How much, "nose down" is OK?
My last set of measurements had the front down almost 2" compared to the back. I'm not totally confident on the precision since it's on my driveway, which isn't consistent.
Is this OK? Or, should I try and move the hitch up yet again?
  • Is your tow vehicle sitting level?.....If so, move the hitch up. If tow vehicle is drooping at back, you should correct that first
  • I think to make another adjustment and have confidence in it I would need to go to a parking lot that's more consistent than my driveway.
  • If you have the ability to make another adjustment to get it more level, then do it. If the trailer is not level, you are putting more stress on one axle and not so much on the second axle. (if you have a tandem axle trailer). You really need the trailer as level as possible.
    There's two ways to make he adjustment: 1) raise the hitch head, or 2) adjust the Weight Distribution bars, and I suppose there's 3)... a combination of both.
  • Level would be ideal....but nose up is not good as it doesnt put enough weight on the ball and could cause sway issues.
Looking for advice before your next adventure? Look no further.25,181 PostsLatest Activity: Jan 22, 2026
