valhalla360
Jun 15, 2017Navigator
I think your dealer has it backwards.
If the trailer brakes work on manual, the trailer wiring is working properly as the trailer wiring doesn't know if it's the pedal or the switch activating the brakes (same wires from the plug to the trailer brakes).
Far more likely is it's in the truck as there are separate wires from the pedal to the controller vs the manual switch to the controller.
Update: checking the gain is a good first check. The wiring might be just fine but if the gain is turned way down, you won't feel the brakes grab.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 16, 2026
