Bumpers53's avatar
Bumpers53
trailor sway
I'm A new member I like this Forum. I hope someone can give me some advice I just bout a Ford F150 its a 3.5 twin turbo and its very lite 5900 pounds We have a 28 ft. Salem I took it on a short run and it was fine but when I took it on the interstate it kept wanting to fish tail at 60 and above I have a WD do I have it to tight I have pulled a lot of trailers but never had this problam any ideas
  • IME the most common cause of sway like you're describing is too little tongue weight as SARGUY alludes. Make sure 10-15% of the trailer weight is on the tongue and then adjust your hitch for a level trailer and no more than about 1/4" rise on the front fenders. Don't mess with friction sway bars until you've corrected the problem. Then you can use them to help with minor symptoms.
    Along with your WD Hitch... do you have a "friction" sway bar attached?
  • Sounds like you might have too much weight in the rear of the trailer,try moving some forward or adjusting tank levels. Don t know much about your type of hitch but someone here will.
Looking for advice before your next adventure? Look no further.25,176 PostsLatest Activity: Nov 14, 2025
