RinconVTR
Jul 28, 2017Explorer
None of those chart relate to modern ATF and Transmissions.
235...not much worry. None at all if its not a sustained temp.
I've had Honda's hit 240 while towing for very brief periods and that's exiting the trans. Which is important to know, because ATF temps are suppose to be measured after the cooler or near the sump. So while some may see a 240 reading, they may not know where that reading is derived from making their concern unwarranted.
Also note, Toyota Tundras and Sequoia's have a thermostat that keeps ATF around 200 at all times. Only recently did I find an app that will monitor highs and lows as the add in temp monitor I had in my Honda. And in all the towing I did in recently in day time temps reaching 121, the ATF temp gauge never budged. It appears automotive engineers might know what their doing.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
