Lucyc858
May 05, 2020Explorer
Travel restrictions
Does anyone know of a website that gives current information on each state's restrictions for entering the state? Thank you for any ideas?
Lucyc858 wrote:
Two weeks without leaving the trailer definitely would not be fun!!!!! Thank you for your post!
K Charles wrote:
I think the constitution says unless you are a felon you are free to travel state to state. States can request but not restrict. But there may not be anything open when you get there.
Freedom of movement under United States law is governed primarily by the Privileges and Immunities Clause of the United States Constitution which states, "The Citizens of each State shall be entitled to all Privileges and Immunities of Citizens in the several States." Since the circuit court ruling in Corfield v. Coryell, 6 Fed. Cas. 546 (1823), freedom of movement has been judicially recognized as a fundamental Constitutional right. In Paul v. Virginia, 75 U.S. 168 (1869), the Court defined freedom of movement as "right of free ingress into other States, and egress from them."However, the Supreme Court did not invest the federal government with the authority to protect freedom of movement. Under the "privileges and immunities" clause, this authority was given to the states, a position the Court held consistently through the years in cases such as Ward v. Maryland, 79 U.S. 418 (1871), the Slaughter-House Cases, 83 U.S. 36 (1873) and United States v. Harris, 106 U.S. 629 (1883)
