MartyW's avatar
MartyW
Travel Trailer - When is it too long ??
Hi all,
I'm a newbie to this forum but I've been towing campers and other trailers for many years, first a pop-up, then 26' class c MH, and now a 20' hybrid. In all the years, about 25' is the longest trailer I've needed to pull.
We're considering a bigger TT for some longer vacations and I'd like to get a reality check by hearing from some folks who have experience pulling longer TT's. And I'd like to hear even if they may have felt their new TT was a bit too long for comfortable towing, even when within weight limits.
We'll be towing with an older, but solid and strong, 1997 Suburban 3/4 ton, 8600 GVWR, 7.4L with 3.73's. Its 4wd rated to tow as is with 3.73's, 8k lbs. The same chassis/engine combo is rated to tow 10k lbs with 4.10 gears.
The newer TT's we've been viewing on the internet seem to go up to 32'-34' and still be within our 8k lbs, as many of them will be in the 6000-6600 lb range dry. It will be just the wife and me and our dog, with only a few hundred lbs of extras. All in all considered, we would be well within the 8k towing max with some of these 32'-34' TTs. The sales folks just look at max limit and say fine, good to go, etc...
But, having seen these longer TT's on the road or in a campground, I've wondered to myself "is that any fun to pull down the road or over a tight bridge, etc"?
Any experienced TT haulers, past/present, I'd be interested in your thoughts as to how long a TT you think you'd be comfortable pulling down the road with our 3/4 ton Suburban.
Thanks in advance,
Marty
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
