Lynnmor
Jan 11, 2015Explorer II
Old-Biscuit wrote:
Without clip spring will push magnet out against face of drum which will cause it to drag.....as it drags lever will move out causing shoes to drag.
The spring will always push the magnet out to the drum armature. This is normal and a slight amount of drag and noise will result. If the OP had an unusual amount of mud and rust, then there will be more drag and noise till it wears in.
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
