Lynnmor
Jan 12, 2015Explorer II
Almot wrote:
Thanks people.
John - no, the pivot arm didn't freeze.
And - no, I didn't take the adjuster apart.
The emergency pin was not pulled, and why should it? The emergency brake was not activated, trailer has been sitting disconnected from the track during the flood and during the cleaning. I only connected the 7-pin after cleaning to check the brakes and help the shoes to "find their place" as described above, by spinning and applying the truck brake.
I tried to pull the emergency pin out, - when discovered first that wheel didn't spin at all, this is before cleaning. The 12V was on, and the pin pulled itself in when I let it go. Well, I am really a newbie with these things. Auto mechanics is not my forte.
Often a pin is accidentally pulled when working with the hitch. The pin probably should pull out completely to manually activate the brakes.
There is no need to connect the truck to the trailer to adjust the brakes, just turn the adjuster till the wheel is very difficult to rotate and then back off the adjustment till there is a slight drag. If you have difficulty doing this, then maybe there is more cleaning to do.
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
