Lynnmor
Jan 13, 2015Explorer II
Almot wrote:
Jbarca - many thanks.
Adjusted the "teeth", good neighbor gave me the tool. Darn guy, he knew how to, but was too lazy to teach or get under the rig himself :)
A Question: how little drag is OK? It can spin now 3 circles on its own, but it also has a play when I apply the brake - I can move wheel a few inches back-forth, and then shoes grip tight.
I also noticed that some drag re-appears after applying the brake, ex. from 3 full circles of spin it goes to 2-2.5 circles, and even if I loosen the adjuster all the way, ~2.5 circles is all I can achieve, and then there is more play with brakes on.
Would you just forget about that brake pedal. You are looking for just a small amount of drag while rotating the wheel by hand. Also, quit counting circles. It is normal to have a bit of free play back and forth, so quit doing that too. You are reading way too much into this simple adjustment.
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
