handye9
Apr 19, 2015Explorer II
You'll probably need a weight distributing hitch. Lightest one on the market is Andersen anti sway WD hitch.
Other hitches run 80 to 110 lbs. Andersen weighs 60 lbs.
Some states / municipalities have ordinances / laws against leaving your WD hitch in the receiver, when not towing. The hitch also hurts quite a bit if you run into it with your shins.
Doing the in and out of the receiver, less weight is good.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
