Red-Rover's avatar
Red-Rover
Traveling in wind
Looking for opinions about towing in wind with tanks full or empty.
Should I have better control with full tanks and more weight or lighter and empty.
What about over the road freight haulers? Better empty or full?
  • I think every trailer will tow differently as fresh tanks are located in so many different places. If your fresh tank is up front then towing with it full may give a higher tongue weight...and perhaps a better experience. If your tank is in the rear it may unload the hitch and give worse handling. Lastly your weight distribution system "should" negate the effects of 2-400 lbs of water. I personally haul water whenever needed and don't worry about the wind.
    Daryll
  • My TT weighs about 8500 lb, I don't think the wind knows if I have a couple hundred pounds of water with me or not.
    When I drove the flat bed was better then the trailer. It has more to do with the size of the sail that is catching the wind.
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
