HoosierDad
May 10, 2021Explorer
Sorry for the long delay in providing additional info.
Tires now have 2,000 miles on them and I tried to pull again last week with the same results. I increased the tire pressures to 65 psi front and 80 psi rear to the door sticker specification and it did not help. I still experienced the same level of movement. I have also noticed an odd very small shake while not towing at highway speed.
Last week, I took the truck to Ford and had then go over it and they indicated that everything looks good and they cannot find any problems anywhere. I had them do another alignment as the last place left the steering wheel off several degrees and I was not going back there again.
I talked to the place that I bought the tires from and they are ready to exchange them without any resistance. Reading a lot of posts, it almost seems like no one agrees on which tires might be a good choice. As I mentioned these were Continentals which were a direct replacement as that is what the truck came with new.
Thoughts on which tire brand to go to now?
Truck 2012 F-250 6.2L Regular Cab 4x4
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
