DiskDoctr
Jun 27, 2018Explorer
After you've checked your adjustment, be sure to check trailer ground. If ground is bad, your system will try to ground through the ball, which can change (violently) when changing force from pull to push, bouncing, etc.
Had these kinds of problems back in the 70's with old horse trailers.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
