freewayrandy
Jun 28, 2018Explorer
JBarca wrote:freewayrandy wrote:
Integrated GM controller. Set at 6.5
I looked up your camper. Nice camper BTW.
https://www.granddesignrv.com/showroom/2019/toy-hauler/momentum/floorplans/328m
Where there toys in the camper when the bucking is occuring? Knowing if toys are in the back may not buck as bad on no toys and if so that will help to know on the cause. Was the TH fuel tank full or empty and where is it located in relation to the camper axles?
Do not know how loaded the camper is, it is a 12,400# dry weight camper and a 16,500# GVWR camper, if you have filled it that full, that is 1 ton truck need. Something less than full may fit in your 2500HD.
A trip to the truck scales my really help in this case. The bad bucking may be coming from the truck suspension being over it's ratings by too much.
I do not think gain on the brake controller is the issue. These new integrated controllers are generally super smooth.
Hope this helps
John
No toys this time. Fuel tank at the very back and almost empty.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
