APT
Oct 20, 2014Explorer
I would start with the weights again. You seem focused on gross combined weight which is not likely your problem. If you have not doe so, you need 3 passes with 3 pads/scales.
The 3 pads are TV front axle, TV rear axle, and TT axles combined.
The 3 passes are TV alone, TV plus trailer tongue on ball, TV plus trailer with WDH.
That will help understand where you stand with all your current TV ratings, how well your WDH is adjusted, and what should be changed or upgraded. If you are 500+ pounds over GVWR or receiver limit, there is little point in spending $20k+ to be in the same situation.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
