skripo
Oct 22, 2014Explorer
Wishin wrote:
The goal generally is to put enough tension on the weight dist. bars to add weight back to your front axle on the tow vehicle so it weighs the same as it did when you did not have the trailer hooked up.
Putting aside the fact that I exceed my total capacity by about 150 lbs for a moment: What happens if I exceed the rear axle capacity or get sag? Can I not transfer some weight to the front?
Wishin wrote:
For example, your front axle has a rating of 3080 lbs. I quickly went back and looked and don't see that you posted what it was loaded to by axle....
Correct. It was not the original post but on page 2:
Skripo wrote:
Weighing results:
Actual tongue weight = 570 LBS
Actual loaded trailer weight = 5200 LBS
Total vehicle weight = 5,800
Front Axle = 2,650
Rear Axle = 3,150
Total weight = 11,000 total.
I am going to modify the worksheet so it can accept by axle.
By the way, why is the collective axle capacity greater than the total posted capacity? Just curious.
Thanks again!
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
