Boon_Docker
Jan 26, 2018Explorer III
eHoefler wrote:ScottG wrote:Boon Docker wrote:ScottG wrote:Boon Docker wrote:
An EZ Lube failure will not make the brakes "stick", it does the exact opposite.
It will make them grab and run hot.
BTDT.
How can grease on brake pads cause them to grab ?
I don't know but it simply does.
The grease will mix with dirt and dust to form a thick paste like substance, then with the heat, it will actually start to turn it into a tar and glue the shoes to the drum
That is understandable, thanks.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 27, 2026
