SimpleMan78's avatar
SimpleMan78
TT-Correct Hitch to use
Late last fall I purchased a new travel trailer (2014 Puma 32DBKS). Dry weight roughly 8,700 with 2,000 cargo...so gross weight of about 10,700. Total length from hitch to bumper is 36'. Tongue weight close to 1,000.
My previous camper hada gross weight of about 8,000 and was 29 feet.
The hitch I have is a Equal-i-zer hitch, which is 1000 tongue/10,000 pound tow capacity. It has no sway control, but does have a spot to mount a small ball and to connect a sway control arm of some sort to trailer. The ball is rated at 10,000.
I guess my question is, do I need to replace my hitch for a higher capacity or will the one I have work...even though my trailer is heavier than what it says.
I am debating if I should purchased a whole new WD hitch with built in sway control or if I can keep the existing hitch and purchase a sway control attachment.
What are your thoughts?
Thanks for your help.
Nick
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
