penguin149's avatar
penguin149
TT tires look askew!
I'm looking at a 2019 Keystone Bullet 243BHS TT and the tires look askew. Not sure if this trailer has torsion axles? I took a couple pics but not sure you can see the issue. The tires on the curb side are not at the same angle/on the same plane/one tire leans more than the other/not sure how to describe! What could this be? It was parked in a somewhat tight spot, so not sure if they are just torqued and would straighten out? Or if it's something more severe. I didn't get a good look at the other side but the axles underneath the trailer looked OK....camber looked about right, etc. Any thoughts or input would be appreciated. Should I keep this TT on my list of possibles or just pass on it and keep looking?
Not sure why the photos won't load correctly? Right click and open in new tab works....
  • ssthrd wrote:
    What do the tires look like? Any uneven wear?
    As a first step, I agree with all above, but what do the tires look like. If you have a bent axle or a spindle issue, chances are good that you will notice unusual tire wear.t thing. Checking is easy. Just look.
    If you search for RV alignment shops in your area, they can check it for you.
    I’d hope you agree with yourself…lol.
    Guessing the owner of the RV might not just want a perspective buyer hauling a TT they don’t own down to the RV alignment shop though.
  • OP here again. Thanks for all your input here. All turned out good with the TT and pulled quite nicely on the trip to its new home! Tires wear looked OK. Now to sell my hybrid TT!!!
  • Tvov's avatar
    Tvov
    Explorer II
    Excellent! and thank you for coming back with an update.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
