DallasSteve's avatar
DallasSteve
Nomad II
Aug 28, 2020
Turning A Toad
Next week I'm going to tow my Jeep Wrangler behind my motorhome for the first time. In addition to reading all the guidelines for hooking up correctly (and making a checklist) I'm trying to find advice on turning corners with the Jeep behind me. My biggest concern is probably how to avoid binding the tow bars and doing worse damage to them, the Jeep, or the motorhome.
What guidance can you give me on how to turn corners while towing a car behind me?
  • The advice of not turning the steering wheel prior to moving is good advice, especially if you have a long overhang on your motorhome. This is a good practice in a motorhome anyway to help avoid tailswing accidents. Depending on your motorhome and toad, the toad may or may not track outside the motorhome's rear wheels. When I had a 30'C towing a little Saturn, the car always tracked inside so I never had to worry about dragging the toad over a curb on a turn. If your toad tracks outside then you have to watch it, especially on right turns on city streets.
  • Make sure you're rolling when you initiate the turn; never turn the steering wheel a lot while sitting still and then move because that immediately puts lots of side stress on the tow setup.
    Never back up.
  • Ava wrote:
    There is advise from manufacturers to try to limit turning the rig at a maximum angle when towing as this puts strain on the tow equipment. Sometimes unavoidable but try to make turns less sharp. As said above, you cannot back up without binding something so always plan ahead to avoid tight roads and use fuel stops that are easy to drive in and out.
    Thanks for the advice.
    I read that I'm not supposed to back up with the car attached, but that's the kind of thing I might forget. So I told my wife to help me remember. And it's on my checklist.
    DO NOT BACK UP WITH TOAD ATTACHED!
  • There is advise from manufacturers to try to limit turning the rig at a maximum angle when towing as this puts strain on the tow equipment. Sometimes unavoidable but try to make turns less sharp. As said above, you cannot back up without binding something so always plan ahead to avoid tight roads and use fuel stops that are easy to drive in and out.
  • The only way you would really be able to bind the tow bars is to try backing up with them attached, especially if you tried to back up while you were turning. Also making a tight U turn. Other wise just tow it the same as towing a trailer.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 17, 2025
