gmg's avatar
gmg
TV mount in cabinent
We have a 2005 Everest fifth wheel with the old style square tv inside a cabinent. I would like to replace the old tv with a new flat screen. As you know the new TVs are wider than they are tall. So what I would like to do is mount one on some kind of device that allows it be outside the cabinent when in use but rotate at an angle and slide or be movable fully inside the cabinent when traveling. Note the living area slide-out only clears the cabinent front by about 2 inches so the tv hast to be moved inside the cabinent when traveling. I’m looking for ideas for mounting. The wall panels are very thin and I am concerned about them being able to support weight of a normal tv mount bracket. Also, the shower is located directly to to back of the tv compartment.
  • After I removed my old CRT, I modified the inside of the TV cabinet so that I couls use a swivel TV mount. Works like a charm. Velcro on the back of the TV holds it in place while traveling. Otherwise, the TV comes out a few inches and can swivel left-right-up-down.
    Plus, there's plenty of space in those old cabinets -- I use it to store my AV receiver.
    It's a 32-inch Samsung:
Looking for advice before your next adventure? Look no further.25,151 PostsLatest Activity: Jul 25, 2025
