randjj1's avatar
randjj1
TV Removal
I have read so many helpful tips on various forums that I thought I'd share my experience in case it might help someone else. I needed to remove the TV in my RV from the mounting bracket - a very difficult task bc there is minimal space to maneuver. The type of mount I have required the use of a long hex key to unscrew 2 screws from the bottom of the mount. After numerous failed attempts using a flashlight and mirror, I was able to remove the screws using a handheld screwdriver base with a hex security bit - much easier. Just FYI.
1 Reply
  • Thanks for sharing that information. Yeah, those well mounted TV's can be difficult to work on.
    Tried to hook up an additional HDMI cable for a ROKU on ours using the mirror and flashlight method you described. What a pain!
Looking for advice before your next adventure? Look no further.25,180 PostsLatest Activity: Jan 23, 2026
