SoundGuy
Aug 22, 2017Explorer
tinner12002 wrote:
... how hard would it be to have say one outlet in the kitchen set up to run a coffee maker on an inverter so I wouldn't have to start the gen...and how big an inverter would a person need for such a setup...2000watt?
I installed a 1000 watt PSW inverter in our trailer's front pass through cargo compartment and wired the outputs to dedicated receptacles - one outside the trailer for powering a fan on really hot days sitting under the awning and 3 duplex receptacles inside, one of each side of the bed and a third at the galley where I can power a toaster or coffee maker. Since we only use this periodically when we're without shore power for one reason or another I run with just one G27 battery - for powering light loads such as a fan that's more than enough but when the inverter is under heavy load from the toaster or coffee maker load supporting it with the truck prevents excessive voltage drop which would otherwise cause the inverter to alarm & shut down. A dozen pics start here.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 10, 2026
