2112's avatar
2112
Explorer II
Nov 26, 2013
Two Space Heaters on 30A FW
We are going to the IL's for Thanksgiving, staying at their local city park for several days. The lows for two nights will be 26 degrees or so and I plan on using two 1500W space heaters while connected to 50A using my 50A-30A dog bone.
Should I be concerned using other items such as the microwave or is it life as normal?
I'm questioning the 30A main panel connection. The house power cable will be on the cold ground so it should handle a little overloading without concern. I hope to have the heaters on separate breakers so I'm good there. Is there anything I should be worried about?
  • RoyB's avatar
    RoyB
    Explorer II
    I would have the propane heater setup for backup - set to a low 40-50 Degree setting.
    We can get away with using two 1500WATT OIL-FILLED heaters on our 30AMP setup but never set high than than 3 on the heat setting. Running high setting ends up tripping our breaker.
    Your RV30A to 50A dogbone Adapter will feed both legs of the RV Trailer Power Distribution ok but just be aware there you will not have 50AMPs of service available. You will have to watch what is turned on at the same time...
    NOTE the two HOT LEGS are strapped together using the standard RV30A-50A Dogbone Adapter providing 120VAC to your two zones in your 50AMP Distribution panel...
    Typical two zone 50AMP Trailer 120VAC Distribution
    Photos from GOOGLE search
    Another thing we do that works out great for us is to run an additional extension cord out the 20AMP Pedstal COnnection just for our space heaters. These will be on the 20AMP Pedestal Breaker and NOT be affected by anything you are doing on the trailer breaker panels.
    AS always - be sure to check for heat build-up when using adapters.
    Roy Ken
  • When at a 30 amp supply and running electric heat.... I run one space heater on high, and another on low (check wattage of your specific heater - they vary)....
    When it's time to make coffee or run the microwave, I temporarily shut off the heater that is set on high.
    I set the furnace at 50 or so as a backup.
  • 2112's avatar
    2112
    Explorer II
    I'll have the furnace running to warm things up and while we are up. At bed time I plan on backing the furnace down a little, leave the gray valve open, placing the shower head on the shower deck and drip the cold water there. The HW side should be OK. Yes/No?
    I'm treading new territory here!
  • I would still run the furnace as that is the only way to keep the plumbing in the basement from freezing.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 17, 2026
