Mortimer_Brewst
Oct 08, 2016Explorer II
A couple of random thoughts: Would it be possible to put cross pieces between joists to give you some structure with which you could attach the membrane? How about using foamboard instead of fiberglass insulation?
Should you go the Coroplast route, try sign shops as a source. I bought some 4 x 8 sheets for $15 each. Some shops wanted as much as $60.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 18, 2026
