Smokey_Lew's avatar
Smokey_Lew
uneven tire pressure buildup while towing with airbags
Hi everyone, here's thanking you in advance for any help you might suggest for this air pressure buildup issue I'm experiencing.
I'm towing a 25' TT with my 2011 Dodge Ram 1500 and using Firestone "Coil-Rite / Work-Rite" air bags. While towing, I pressure the bags to 30lb using a compressor mounted next to the battery under the hood. The issue I'm having is that the Ram's tire pressure monitor consistently shows my right rear tire building up three lbs. more pressure than the left tire while towing.
I set my tires to their maximum 50 lbs cold pressure as stated on the sidewall before towing. The two front tires will build pressure to about 54 or 55 lbs. while the rear tires will build to about the same on the left but about 3 lbs more on the right. In this example, 55 to 57 on the left and 57 to 59 on the right depending on how hot the outside air temp. is. I try to keep the towing speed at between 60 and 65 mph.
Any ideas on what may be going on? Could it be an air bag issue? The tire pressures stay consistent right and left when the bags are not inflated (normal pressures set at 35lbs all around) and I'm not towing. The people who installed the bags for me said they have never heard of this kind of a problem related to the air bags. Any help would be appreciated.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
