Off_Pavement's avatar
Off_Pavement
Explorer II
Jul 14, 2013
Unified Tow Brake - Review
I want to review US Gear's Unified Tow Brake(UTB)because it gets badmouthed for being "complicated" and causing problems, often by folks that don't have one, and never have... one fellow on here adamantly states he doesn't like electronic controlled systems because it's a complicated design, prefers NSA's ReadyBrake, but doesn't have a supplemental brake system of any kind for comparison. Most other folks on here that like the ReadyBrake swear by them for never having a problem and simplicity and I totally respect those opinions, but the truth is there is no perfect system out there. A simple Google search will show somebody had issues or problems of one sort or another with every supplemental brake system manufactured.
The four reasons I chose the UTB over other designs...
Every time we camp we tow our Jeep, and we usually camp numerous times per month year around. We often travel thousands of miles on a trip too, so ease of hitching and unhitching during those travels becomes more important to me as we've hitched/unhitched as many as 4 times in one day. Once properly installed, there is no easier system to hitch up... period! The same ease of hitch up is available with the Invisibrake by Roadmaster (which I had in my '97 Wrangler), but it doesn't allow adjustment of the brake system from the towing vehicle like the UTB does(see below).
Ability to adjust towed vehicles brake activation from towing vehicle. I find this feature of the UTB very handy. Braking requirements seem so different between mountain driving and city driving, and the UTB allows for more aggressive brake operation when I want it in heavy traffic. It also allows manual operation of the towed vehicle brakes which I have found extremely helpful on snow packed and icy roads.
Energized brakes in the towed vehicle. The UTB has a vacuum pump that charges the power brake system. If you have ever tried to stop your vehicle with no power brakes, you understand the brute force required to stop. I'm not an automotive engineer, so the amount of pressure put on the brake pedal by any system that doesn't charge the brakes may not be of any consequence, but it obviously puts a high stress on the supplemental brake systems that operate without power enhanced brakes. Additionally, you don't need to purchase anything else for a break-away emergency brake either as it's part of the UTB design. You also don't need a separate battery charge line, it's in the design.
Lastly, in researching brake systems, I discovered a few folks had issues with the surge brake design and mountain towing. The however infrequent issues of others, along with the fact that the UTB has what I consider to be great proportional brake operation, is why I chose the US Gear Unified Tow Brake system.
Yes, the UTB is a complicated design compared to some other available supplemental brake systems. But that is exactly why I chose the design to overcome what I perceive as shortcomings in other systems.
Here are a few photos of the installed system on our '13 Jeep Wrangler...
This is the vacuum pump that energizes the power brakes. If you look closely, you will see the check valve and "T" fitting in the vacuum line.
This is the brake activator. It is mounted on the passenger firewall well out of the way. The cable on the left side of the picture routes under the carpet to the drivers side...
This photo shows how the brake activator cable above is hooked to the brake pedal...
This photo shows the control box in the towed vehicle. In our Jeep, I mounted it on the high on drivers side under the dash...
This photo shows the towing vehicle's dash control. The lever is for manual activation of the towed vehicles brakes. The knob on the top adjusts how aggressively the towed vehicle brakes are activated. It includes warning and activation LEDs, and malfunction alarm...
How it looks ready to tow...
To sum it up, I recommend the US Gear Unified Tow Brake. It has been reliable, and it's versatility in all towing conditions can't be beat in my opinion.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
