Diesel_Camper
Aug 20, 2014Explorer
Uninteruptible Power Supply as RV Inverter?
So I was looking at some rack mount UPS's on ebay and it looks like you can get some decent deals... About $100 for a 1000 watt Pure Sine rack mount (professional) system with no batteries.
What if you were to install such a system in your RV inline with the general use circuit (Not the Air Conditioner circuit)? It yould be in line passing the normal 15 amp load through as long as you were plugged in to shore power. Unplug and it clicks over to your house batteries and provides up to 1000 watts of pure sine electricity to the non air conditioner circuit in your RV. Flip the switch and turn it off when not needed or keep off until needed... Of course you would have to disable your converter at least while operating the inverter... Plug back intoshore power and it starts passing shore power through and trickle charges your batteries. It seems like someone with a bit of understanding could wire this up safely. I don't think these things are known for bursting into flames when they kick on...
