CaLBaR
Jul 21, 2020Explorer II
Humbert810 wrote:
Currently have the Pro-Series 12,000LB 1,200 Round Bar hitch set-up
My question is if I upgrade the the Reese 1,500 LB Trunnion Bar hitch, with the capability to add DC sway control later. Will my current shank have the same hole spacing or will I need to purchase a complete new shank for the new head?
Thanks
Humbert
I have upgraded a number of times and still use the same couple of shanks. Hole spacing is pretty much standard so as long as you have the height adjustment that you need no new shank should be required.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
