DannyA's avatar
DannyA
Used generator first time
Hooked up my Champion 3100 watt to the 5th wheel for the first time today. Worked great, tried air and even in economy mode ran the air just fine. With generator 20 feet away only a faint sound of it inside camper and with air on no noise from it at all. The only question is it showed reverse polarity on my surge guard, is this normal? Think I will like it very much if this polarity thing is not a problem.
  • RoyB's avatar
    RoyB
    Explorer II
    enblethen wrote:
    The genset does not have a connection between the neutral and ground. This is common. You need to make a dummy plug that ties the neutral and ground together. This will lie to the Surge Guard.
    I had to do this with my 2KW Generator using an ADAPTER with the SHORE POWER CORD plugged into the 120VAC connector on the generator... My problem was one of my GFCI receptacle was tripping on me...
    Google Images
    Google Image
    Don't know if this will solve your problem or not but this does tie the GROUND and NEUTRAL connections together coming from the generator...
    Roy Ken
  • The genset does not have a connection between the neutral and ground. This is common. You need to make a dummy plug that ties the neutral and ground together. This will lie to the Surge Guard.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 02, 2025
