wa8yxm
Sep 09, 2018Explorer III
rirish1 wrote:
Would it cause any damage to the onboard converter if I used an external battery charger to charge battery. Should I disconnect the battery when charging? What if the TT is connected to shore power? The WCO converter does not charge very well and I do plan on replacing it but would rather replace it when it breaks.
Damage the on board: NO
Disconnect: Depends on the charger
Suggestion. WFCO converters have a known failure mode that is very common. won't go into BULK.. So they go straight to FLOAT so it takes forever literally and the battery is never really full.
YOu can replace the "GUTS" of an integrated Converter/distribution panel with a Progressive Dynamics 4600 class *match the last two digits as closely as possible to your WFCO's. Ie xx60 use a 4660) or if the converter is not part of the Drstro panel but a stand along go with the 9200. ANother advantage is these are made in Marshall Michigan, USA. not some sweat shop in China. Quality USA made products. The replacement is not that hard.
You can also use a 9200 as your external charger if you wish. No need to disconnect if you do.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Oct 17, 2015
