BFL13
Sep 10, 2018Explorer II
The Boondocker version has a 3 year warranty from bestconverters, but the regular PowerMax normally has a 2 year warranty.
If you got the newer type with LK in the model name, then you have choice of three stage automatic or else you can set any voltage you like for as long as you like manually. Read the instructions carefully before playing with the switch and pot behind the two holes in the side.
The LK frees you from the fixed three stages you get with most converters when you want to operate that way, or you can use the automatic three stage mode.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Oct 17, 2015
