time2roll
Sep 11, 2018Nomad
kellertx5er wrote:Ok and that is the easy part.
I don't consider the use of ALL of my 12V accessories a "low expectation."
Does it put 14.4 volts on the battery when you need a fast charge from the generator?
Does it actually drop to 13.2 volts in a couple days to float the battery giving longer life and lower water use?
Does the WFCO give a periodic boost charge to reduce stratification and provide a little equalization?
The good converters do all this very consistently. WFCO not so much but claim they do.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Oct 17, 2015
