cross21114
Jun 05, 2019Explorer
Dutch_12078 wrote:
Make sure you remove the toad's E-ZPass and store in the shielded bag so both tags don't register. The NY Thruway E-ZPass Motorhome Plan requires a separate tag available when you send in the application and a copy of your registration.
www.thruway.ny.gov/ezpass/ta-w68176.pdf
To further explain - both passes will register. The RV will carry the tolls of the combined unit and then an additional charge for the toad will be charged. We take the Ezpass off in the toad and put it in one of the special foil bags they provide to prevent the double hit.
In many cases, the combined toll is more than each individually. So if you disconnected and pass thru the toll booth and then hook back up, you can save money in some states.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: May 25, 2024
