wa8yxm
Mar 16, 2019Explorer III
On some fridges you will find a switch or two.. May have to look for 'em they will be at the top of one of the doors (not sure which without getting up an dlooking)
One may be marked "Enviormental" or something to that effect. Turns on a heater that is along the door seal to cut down on moisture around the seal area.
The other (if you have two) is often marked LAT (Low Ambient Temp)
YOu know the old question kids ask "Does the light in the refrigerator go out when the door is closed?" (normally yes it does but if the LAT switch is on it does not)
The heat of the light bulb makes it work better.. Won't work with LED lights though.
