We are told not to empty the black tank unless it is 2/3 full so that the liquid carries solids as the tank is dumped. I assume the rush of liquid does not occur with the sani con. Is the pumping acti...
Anybody try the technique of keeping your black tank valve open after dumping with the Sani-Con, and then opening the gray valve to backflush into the black tank?
That was recommended by a Thetford engineer, and published in a paper at an FMCA session.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 27, 2026
