nipcam
May 13, 2013Explorer
Using sani-con
We are told not to empty the black tank unless it is 2/3 full so that the liquid carries solids as the tank is dumped. I assume the rush of liquid does not occur with the sani con. Is the pumping acti...
thestoloffs wrote:
Anybody try the technique of keeping your black tank valve open after dumping with the Sani-Con, and then opening the gray valve to backflush into the black tank?
That was recommended by a Thetford engineer, and published in a paper at an FMCA session.
